G
Guest
·X( I just bought a ´72 GT. At first the alternator didn´t seem to work. I found a wire attached to one of two bolts comming out of either side of the alternator and another wire that didn´t seem to go anywhere. They looked as if they once went together so I attached them. Now the altenator works. I can disconnect the batt. cables when running and it keeps running. Then it stoped working all together. No electric at all. guages didnt move, no lights, no engine crank, untill I accidently kicked the fuse box (strip). Then It worked again. BUT! now I can start it and drive it but when I shut it off it won´t start again for 20 to 30 min. Seems like something is getting hot and has to cool down. Any advice might help. Thanks
