101 - 120 of 142 Posts
Discussion Starter · #101 ·
Picking up the new hood and fenders tomorrow. Been working on the engine bay mostly, relocating the radiator so I had room for a mechanical fan and could get rid of the electric pusher fan. Cut out the inner fenders and did “down bars” for the upper shock mount, original upper shock mounts I did kept ripping the stock inner fender. Once all the fab work is done I with wash and paint, then when the engine is done(almost) I can put the drive train back in.
Discussion Starter · #102 ·
I picked up my fenders and hood today. Did not look at them much, simply tossed on for pictures (sneak peak of the kadett for those that wanted to see it). Did some more cutting, grinding and welding today too. Hoping to have the car ready to go for the 50th manta drive/meet if I can make it, anyone know the date and location of this event? I heard April
Discussion Starter · #103 ·
Engine is back in, did not get too much further then that today though. Hopefully trans and driveshaft will go in tomorrow. Still need to bolt the headers up, get the radiator serviced and reinstalled as well as bleed the brakes among the other small things to button it up.
424893
424894
424895
Discussion Starter · #104 ·
Money has been tight, not getting much done but doing what I can.
Reactions: 99449 and Vincent
Look really good!!!!
Discussion Starter · #106 ·
Thank you
Read Only
That's a beautiful engine :) Balancing time and money can be difficult. Sometimes you have more time than money or more money and no time ;)
Here is a short video, engine still hasn’t been tuned at all(timing and carb) but I had to hear it. Wish it was lumpier but the cam has a 112 lsa.
Sounds evil!!!
Discussion Starter · #109 ·
Unfortunately not much drive to work on cars lately. I did buy front suspension bushings and box flares though. A few set backs and some work here and there mostly but I am still working on it.
Reactions: JudokaJohn
Discussion Starter · #110 ·
Started on my front suspension bushings. Bolts on my rear flares and put on a new wilwood brake master. Looking to build some 3 piece wheels to get the perfect offset for the flares.
426868
Discussion Starter · #111 ·
I finally got my hands on 4 dellorto drla carbs. Just ordered rebuild kits, venturis, linkage etc. already had the intake. It’s exciting to think In a couple months I’ll pop my hood and have this sight.
427654
427655
Discussion Starter · #112 ·
Forgot to mention I measured for my 3 piece wheels. Doing 15x10 rear and 15x8 front
Discussion Starter · #113 ·
My wheel parts came in, just cleaned the old paint off the centers, trying to decide what color.
428665
428666
428667
Discussion Starter · #115 ·
I hope so, this has been my longest build, I’m excited to get it back on the road.
Reactions: G.v.Mainberg
Your Noble Friend ;-)
I think I missed this thread when it started, but maybe later tonight I'll go back and read the whole thing. I love what I just saw so far in the last few minutes!!!
Dieter
Discussion Starter · #117 ·
Still not much work being done, new Lancia scorpion has my attention, but I test fit the wheels. My measurements were off but it looks like the new wheels will work just fine.
428842
428843
428844
Discussion Starter · #118 ·
I picked up my radiator a few days ago, have only done a test fit so far.
429053
I picked up an automatic radiator, thicker core, and took it in to get cleaned up and a few modifications. I ended up having them remove the oil cooler as well as build a new 3 row core for it on top of that. I hope it’s money well spent.
Reactions: Vincent
Discussion Starter · #119 ·
little over a year later she runs again! Drive it from the back to the front, still a lot to do before I can cruise around.
430222
Discussion Starter · #120 ·
The needle and seat are giving my issues, overflows even if I turn the fuel pressure down, so I have not been able to tune it. Parts on the way to fix that, in the mean time I need to bleed the brakes and I should bench bleed the new master cylinder first I guess. It’s been about 15 months and I have a feeling I started multiple( I remember a couple) projects that I did not finish so I’m going to have to go over the whole car. Planning a real test drive in the next week or so and I’m hoping it everything goes well so I can drive it a bit before poor weather/winter hits( no heater or wipers).
