1 - 4 of 4 Posts
hi do you know if the 6 cylinder cih motors take the same porting touches as the 4 's as ive just been offerd a 3.0 Litre injected senitor with 5 speed and think this is an easyer option that the jag V12 way that im doing at present
i know that cams are no problem and the injection is easy to boost depending on type(mechanical gets the bob weight lightend - electronic gets chipped) :)
In a word, 'yes', the 6 cyl. CIH engines respond well to porting work, in fact about 50% better based on displacement!
thanks for the quick responces
this should shave 1/2 a ton off the weight i was looking at.
The crossmember and brakes look good but im going to use a toymotor supra front end (alloy whishbones and very good brakes) then to compleate the conversion as my dash is junk im going to make it right hand drive so i can see where im going for a change
1 - 4 of 4 Posts
