1 - 20 of 37 Posts
I just picked up a front Addco sway bar and the instructions/diagrams are little confusing. I'm confident once I get uder the car, things will make sense. However, a picture is worth a thousand words!
Has anyone posted pictures of their front sway bar installation? I ran a search and didn't find any.
Thanks, Richard
Moderator
Well I guess sending members to another site is OK if it's all in the name of Opels. Go to the ClassicOpels webite that is hosted by Yahoo. The URL is:
http://autos.groups.yahoo.com/group/classicopels/
I've got about a dozen pictures of my Addco front and rear installation. Go to "Files" then go to "Technical Information" and there is a folder named "Addco F&R Sway Bars for GT".
I got the bars front and rear for $99 each, all hardware and poly bushing. Buy some teflon grease and goop the bushings up well, otherwise they squeak and groan like an old wooden staircase.
where did you get the swaybars from? because OGTS wants 150 just for the front stabalizer bar kit.
Moderator
Call Shelly at Addco 800 621-8916. Last year I bought the last front bar they had in stock. I had to wait about 2 months until they did another run of rear bars.
The Addco rear bar does not require a bracket to be welded onto the axel like the OGTS bar does. The bar mounts to four tapped body holes that were there on my '73 GT. The hardware provided just screwed right in. The end of the bar mounts up to the lower rear coil spring cups via a bracket that is mounted to it.
I can't comment on how the Addco bar compares in actual performance to the OGTS bar. I just went with the easier installation, since I don't have welding gear. Adding the bars does make a heck of a difference in handeling. Well worth the $200 to me.
The Addco bars are a nice deal, they improve the handling of a GT for a reasonable cost.
However, the OGTS bars are far superior to the Addco bars for performance handling, and the fitment in many ways is easier, as they attach to the chassis using the same fitment points as the factory (Euro) sway bars. So if you have a Euro set of front lower a-arms and a rear axle with the Euro sway bar brackets, they bolt right up.
Pathologic Opeler
suspension upgrades
1)Which is more important for the gt....A) front anti sway bar or B) the back(if a person had to choose only one for his birthday)
2)Rally Bob:how is it possible that the OGTS bars are better?Do you mean they are better for racing..i Believe the diameters were
very close in size.I have also heard that kadette bars will fit..are there any availible sources?
3)were any Gts shipped to the US with sway bars?..if even a few were shipped..i am told they could then be added on to an existing Gt and be
scca classified as a stock car.W/o this verification of shipment..then the addition of sway bars changes the gt to an upper bracket.
4) people i have met at the scca ..say this is the most important upgrade that is needed on the gt..they say it is a night and day change in handling.
5)I have heard of removal of the front leaf springs and replacing with coil over the shock..is this a good idea?
crazy opeler
1. I found this on the Yahoo site, that way Mr. Legere doesn't have to write it again
"*****They *should* be done in pairs. Doing just the
front bar will make the car understeer (front end
loses grip first), and doing just the rear makes the
car oversteer (rear end loses grip first). If done in
pairs, the balance will be improved, and the car will
be easier to drive fast. On a stock GT, the car
understeers badly, so the rear bar would be the best
improvement for lower speed corners, but it will also
create a high-speed instability during cornering, so
just beware. It won't be 'Porsche 911' bad, but it may
catch you unexpectedly if you were to lift off the
throttle mid-corner.
BTW, a performance driving school for the driver, and
good tires and tire pressures are the best thing you
can do for ANY car's performance.
2. The OGTS Bar is Bigger in diameter on both ends and is of thicker metal I believe, they are much stiffer.
3. I actually have a rear end with the brackets on it, but I have never heard of or seen a GT with factory sway bars. You would be better to just have a later model rear end fitted with brackets.
4. TRUE
5. It may sound like a good idea, but it is a lot more work than you might think. The uni-body gt was designed to handle the stresses and strain of the leaf spring setup. If you add coilovers you will have to attach them to portions of the body that were not designed for or can handle the forces of the suspension.
That being said some people have done it. I believe Uwe Klippert had done it to his gt and there were pictures of his conversion on his site http://www.uwe-klippert.de but there is somehing wrong with my browser and I can't seem to navigate his site.
Gary....where did the spel kheker go?
Ask yourself, "What am I trying to accomplish?" This is the real question, it'll get you real answers.
Are you trying to,
1. Fix a handling problem (more enjoyable to drive), or
2. Upgrade to a new performance level (e.g. for racing).
Most street driven cars are shooting for number 1. On almost every car I've bought I've fixed handling problems that came from the factory. On my last one I replaced the rear anti-sway bar, shocks and tires; and adjusted the tire pressures. Originally, it had excessive plow and tail wag (like a GT). Now it's nearly neutral with slight understeer and the back end doesn't roll excessively. It's a lot funner to drive and I'm not as nervous in emergency situations.
Factory cars are targeted at such a wide market the number of compromises eventually compromises the handling and occasionally safety. US sold GT's have some handling problems because some butthead at GM thought a rear bar caused a harse ride (more likely it costs money). Opels are sports cars and should drive like one, not the family Buick.
There are several good suspension books and articles on handling. They tell you the basics and fixes. This is a good place to start. Ideally, all the parts must match, for example, the stiffness ratio between front and rear anti-sway bars is correct. There are many suspension adjustments that can be made w/o new parts. I'd change one thing at a time and work to a goal.
Too many people buy mismatched parts or use inappropriate performance parts. Harder/stiffer suspensions are more difficult to tune. They seem to amplify every little thing, like bumps and adjustments. This takes the fun out of driving on the street.
Pathologic Opeler
kadette rear sway bar to gt
well I am very happy that I bartered a rear kadette sway bar through this site. I know it is not as stiff as the others,but it is all opel and unique. It is better than nothing.
It is a 5/8 in (which is a smaller diameter) than the OGTS 3/4 in. OGts does not sell bracketry for the Kadette bar but they sell the hardware separately
($80 yikes) plus $60 for a pair of bracckets (Yikes again) for the 3/4.
so I am trying to adapt new brackets to the old bar. I dont have a picture of the bar because a friend is powder coating it for me.
in ideas on how I make it fit with the diameter difference?
Administrator
Try Summit http://www.summitracing.com They may have 3/4 inch swaybar bushings.
I just picked up some 7/8" poly bushings at Pepboys for my Wagon. ($15.00 with clamps that have grease fittings)
Man what a difference that ADDCO bar makes over the stock one!
After reading numerous posts on the sway bar issue, it seems to be that everyone is happy with either the Addco or OGTS SwayBars. I've been debating for months which one to buy. Here is what I have came up with from the various posts.
The OGTS is stiffer than the Addco (front)...is it that noticible of a difference? I'm like the OGTS for this reason.
They both have the same ease of installation (front)..true?? Tied
The rear sway bar, the OGTS needs welding for the brackets and the Addco doesn't..since I don't weld, I like the ADDCO for this reason.
I shouldn't mix an OGTS front with Addco rear....correct?
So now I'm back to square one...I like OGTS front and Addco back...so my first question will probably make my decision..is the stiffer OGTS front make that much of a difference for the stock street rider?
Thanks.
i have heard from one member that the front bar was also pretty hard to install. i cannot say for sure, i've never tried one. addco front bar took me an hour, the rear bar took me an hour and a half fighting with a spring. i wasnt too carefull where i drilled the hole in the srping bucket, it was my fault for that difficulty.
The front Addco is a straight bar 3/4 of an inch thick and the OGTS is 1 inch with a drop for the pan in it. You have to be careful with the OGTS front to not get it into a bind between the front cross member and the Addco has a limitation if you want a bigger sump or maybe one of those finned oil pans.
The rears are very similar with the exception of the size and mounts. Addco mounts to the spring cups and OGTS requires welding the brackets to the axle.
I went with the OGTS front and rear since it is the best on the market but it was a bit harder to install. There is also a bit of a price change for the two in comparison. To answer the mix and match question, you should never run different diameter bars front to back for alot of reasons.
A Matter of Taste
It all depends on the sort of handling you want and how harsh a ride you are prepared to put up with. As an "old" Dirt Track" Racer I like the tail end to break free first (oversteer) and don't mind a flick or two of opposite lock at the limits. Also as an "old" driver comfort is more desirable than real hard suspension. So I guess a bit of a play around with different size bars front and back may be in order.
Rear Only?
How would the GT handle if you installed the Addco rear sway bar only? Then maybe installed the front at a later time? Is there really anything wrong with that?
Pathologic Opeler
from what I have read
and if you read what flipper has said and I believe others have said,
If you are to install only 1 bar,install the front. I have used only a front ogts bar for the last 6 months or so, it makes a big difference. Someone posted
on just having the back on, not much improvement.The front bar keeps it from diving in a corner. I guess the risk is if you keep pushing it the back will break loose. I think, if you are not a racer,there is no problem with the front only and the car is a lot better handling. I think the addco is equivilent in daily performance to the ogts.. Jimsky really liked his addcos.
MY experience,as a newbie, the OGTS front is simple but hard to install by a fraction of an inch.you will have to horse it in with a jack.
I am putting on a used Kadette bar for the back. the bar was bartered so it cost me nothing, but I will have at least $160 in costs to adapt it in. I am sure the Addco would be better and cheaper than mine, I just like the fact
that my rear bar came off a kadette bound for the junkyard. A friend will weld it in for me on wednesday.I am buying MG midget polybushings for the body anchor points ,since they are 5/8''.
my opinion,the best bang for the buck seems to be the Addco bars.
1 - 20 of 37 Posts
