Help starting 72 GT
I installed a Crane XR700 and a Petronix Coil. After toiling with it a fews (replaced rotor, wires, electric fuel pump) trying to get it to start I finally found that I can't get the shutter to line up with the optical trigger.
I lined up the timing mark with the timing pointer on the pully and made sure the rotor pointed directy to the mark on the distributer, but the obtical trigger is off. It does not line up with the shutter break points and I believe this is why I can't start my Opel.
I use a test light in the instruction for troubleshooting and the test doesn't flash on and off, it just dims just a tade bit.
Can anyone give me some idea's on how to get the optical trigger to line up correctly with the shutter break pointes?
Thanks for your help!...
