This is a very interesting thread. I have saw people put this on their cars like on hondas and I think a air filter like a k and n can fit in the hole. Would this work as a ram air? I guess it is called a velocity stack.
Buy 2.5" Performance Filter Kit - Includes Composite velocity stack, filter, and silicone hose kit: Air Filters - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Free Shipping - Vibrant Performance Bellmouth Velocity Stacks with qualifying orders of $99. Shop Turbocharger Bellmouths at Summit Racing.
www.summitracing.com
Sam-
(Everyone feel free to correct anything from this point on...)
One thing to understand about these things is that many of them are attempts at correcting losses not actually gaining anything. Air is a gas, gasses move like fluids...so it's easier to visualise how water acts (since we can see water!), or better yet, how large crowds of people move when exiting a sports arena.... Ever notice how some toilets have a nice smooth flow when you flush and others are very turbulent? Air moving into and thru an intake tract is much the same. The carb can only flow a maximum amount of air at wide open throttle no matter how good the rest of the intake tract is, both before and after the carb.. But intake tracts are full of bad things, like sharp edges, right angle turns, ridges, accordian textures, drain tubes, under hood heat and all sorts of things. All of those things conspire to slow down the air flow thru friction and turbulence (this where the exiting crowd analogy comes in handy). There is a thing called a boundary layer where air along a surface (like inside the intake duct) slows down due to the friction against the duct wall, yet the air in the middle of the still flows faster. The crowd in the center of the exit corridor moves faster than the people along the walls and the people lined up with the door way go thru while those on the sides bunch up and have to squeeze thru, slowing everyone down. Watching a river flow shows the same thing. faster moving water further away from the bank and slower water along the edges and even areas where the water is still.
Anyway, the velocity stacks/ram tubes don't gain anything, just correct an inefficiency. Ram Air is usually not really ram air, but more often than not an attempt to either reduce losses in air velocity at higher rpm due to convoluted intake ducts or to get cooler air from outside the engine bay as cooler air is more dense therefore more oxygen molecules to burn, but under hood air can get pretty hot, which does two things, it gets less dense (fewer oxygen molecules to burn) and the hotter air has less of a cooling affect on the carb and intake.
Here is the Weber DGAS version of a velocity stack:
Low Profile Velocity Stack (Air Horn) for Weber DGV or DGAS - Pegasus Auto Racing Supplies
On a naturally aspirated motor it's all about reducing losses due to most parts not being perfect or optimum. You might be increasing hp/torque over the factory rating, but that rating is still based on loss in potential acceptable to the engineers and the accountants. In engine rebuilding that is what 'blueprinting' is all about since few motors come out of the factory perfectly built.
The only ways to really 'gain' over the designed in potential of a motor is with turbos, superchargers, nitrous. Or run 200 mph at Bonneville
Or all three...like this:
