1 - 20 of 207 Posts
I am organizing a group buy for Aluminum DOUBLE GROOVE Crankshaft Pulleys.
The cost won't be completely confirmed until the machinist and I meet face to face. The cost will be LESS than $150. I don't know how much less.
The design is attached.
The details.
6061 Aluminum.
Anodized
Uncolored
63 finish before anodizing
Designed to accommodate a custom trigger wheel for EFI
The more we buy, the cheaper the get (I assume)
We need 10.
Posting that you want one of these Crankshaft Pulleys constitutes a contract. You can ask for as many as you like.
The order will be confirmed on 7/31/2017. I can't guarantee I will ever do this again.
I am purchasing a minimum of 2 for myself
We have 3
OK....I am in for ONE.
Will you be doing a group buy for 36-1 trigger wheels and if so will the outside diameter be 6.100" for use with the special oil pump cover or some other dimension?
The 6.100" diameter would not stop anyone from making a bracket to be mounted elsewhere.
I had asked for 2 of the double grove pulleys. Thanks, John
Discussion Starter · #10 ·
myself - 2
kwschumm - 1
jmbinjax - 1
opelspyder - 6
markandson - 1
Binnacle-ZA - (?)
guyopel - 2
anastosmotors - 1
14 so far
Reactions: guyopel
Discussion Starter · #11 ·
Last call.
I met the CNC guy a couple days ago. We agreed that we should do a one-off "sample" to send to Keith for fitting and inspection before we make the full run. As soon as the one-off is done I will fir it on my engine (in a stand) and then send it to Keith. That way it will have two fittings to make sure everything is good to go.
As soon as Keith gives his input, the run will be sent to production.
Reactions: guyopel
Last call.
Good plan!
Discussion Starter · #16 ·
Discussion Starter · #17 ·
myself - 2
kwschumm - 1
jmbinjax - 1
opelspyder - 6
markandson - 1
Binnacle-ZA - (?)
guyopel - 2
anastosmotors - 1
Lindsay - 1
15 so far
1 - 20 of 207 Posts
