1 - 20 of 530 Posts
Administrator
There were aluminum ones made for the S-10 clutches some years ago, but never a run of steel flywheels....
I am in contact with a company who has all the specs and CAD program for an aluminum flywheel set up for the S-10 clutch. Their initial quote for a one off make of a modified version of the standard 1.9 set up was a lot higher than our last buy (Added cost for programming)
If there is enough interest, I will look into the cost for a "group buy".
1000 Post Club
Could this be used with either the Opel or S-10 Clutch assembly or just the S-10? If it is just the S-10, could they tap the flywheel for the Opel pressure plate so we could use either? Just wondering
What year/engine set up is the S-10 Clutch from?
I had an '87 S-10 4 cyl with the 4 spd and that thing went through clutches every 50K.
It was the 2.5l with the Izusu transmission.
Nope. Because an aluminum flywheel has a steel friction insert for the clutch disc to ride on.
Opel clutch: 8" OD.
Chevy S-10: 9.125" OD.
They won't coincide, even if you drilled two patterns.
2.8 V6, I seem to recall it was '85-'92.
I had an '87 S-10 4 cyl with the 4 spd and that thing went through clutches every 50K. It was the 2.5l with the Izusu transmission.
I believe that used a much smaller clutch than the V6 version.
1000 Post Club
Thanks for the info Bob.
Once a price is announced, that will determine if I'm interested. It would be used for a regular high compression 1.9 for street use.
1000 Post Club
Another dumb question, does the aluminum flywheel have the "ball" in it for TDC timing mark?
Also to add to Bob's reasons, the Opel clutch must also have the pressure plate mounted ~1/2" (IIRC) away from the friction surface via a raised crown on the stock cast flywheel.
Opel clutch: 8" OD.
Army Rotorhead
Count me!
Gary,
I'd be interested.
Thanks,
Lance
Vendor
Don't know about the ones being planned currently, but the ones we had made up before had a dimple drilled for the timing mark.
9 lbs? Is that a little light for the street?
I have no issue at all. If I didn't tell you and you drove my car I don't think you would know the difference.
Just heard back.
Retail is $465 for 1.
5 pieces - $350 ea.
10 pieces - $315 ea.
I believe they are the company who made the last batch for Unorthodox and they do have a timing mark.
That is a temptingly good price and I guess that leaves me with a couple of questions for the engine gurus, you know who you are :cool:
Would you recommend a flywheel as light as this for a 2.7 stroker engine and would there really be much point since it's not an engine that will rev all that high ?
I'm trying to get my head around the rotational mass and long stroke vs short stroke engines, high revving engine vs not so high revs ..... and all I get is a head ache, this is something I haven't really read up on in the past since it's never really come up so I'm just getting :confused:
Just heard back.
5 pieces - $350 ea.
Great pricing. I seem to recall paying $409 each when we did a group buy years ago. Helps to take out the middleman from the equation!
Great Price
That's a great price! The last one I headed up was $350 a piece plus shipping of $100 for all ten to one location.
1 - 20 of 530 Posts
