Right side air pump bracket . . . '68 1.9?
RallyBob said:
Otto, if Dave's pulley doesn't pan out I should have one too. No aluminum compressor brackets though, the ones I have are steel.
Thanks for the twin pulley offers from RallyBob and nobody. Found an extra right side GM compressor bracket, BTW, but not going to work for what I want to do, so I'm not going to just cut it up.
Anyone have a cast iron air pump bracket or two from a '68 1.9 engine . . . and, maybe, an air pump that goes with it?
Two different projects: bracket and pump - modify pump to use in reverse (vacuum) to evacuate my 2.15 SSD crankcase; bracket only - modify bracket for mounting Nippodenso 10P08E compressor (very small, rescued from junk-yard many years ago for use in Opel) for hand-fabricated A/C in '69 Kadett.
Based on ~630 mile round trip to San Antonio last weekend, these old bones don't take too well to long, non-A/C drives in the summer heat down here anymore. A/C is on front burner, as I'll likely take '69 Kadett to OMC . . . if I go. Now you know . . . any of those in anyone's stash somewhere? I'll document and post on one or both projects.
