fan too
To top it all off, the condenser sits right up against the support brace in the front, so no room for a "normal-sized" electric fan on the front either.
One other issue of concern in the Kadett with AC was the fan. The 1.9 motor is so close to the rediator that you can't space it forward to clear the pulley like the Manta and GT, instead they cut away the rear 1/2" of the fan instead to clear the pully. Doing it and keeping it balanced is a real chore if you have to do it to one yourself. Do yourself a favor and start out with a 7-blade one, though, to keep as much fan as you can.tekenaar said:Is the alternator/water pump V-belt driven from the rear pulley of dual crank pulley?Assume so . . . thanks.
