Dave;
That's cool, I'll keep an eye peeled for it
Gene
Gene
Still looking for twin pulley A/C crank pulley and right side (Manta/1900), aluminum A/C pump mount . . .BQS4 said:Dave;
It seems I have run into a batch of Mantas. I have one parked in the driveway right now (74 Rallye, rust bucket, being stripped for parts) and another waiting for me out in west GA this weeked (another 74 Rallye, again a rust bucket, but, has great parts) and another 75 Manta in east GA I intend looking at this weekend (again, another rust bucket waiting to be stripped)
Neither . . . I'll be using Duracool, a really 'cool'ddoyle said:Nice work Otto, lot of work in the comp mounts! Are you going to use R-12 or 134-A for your A/C system?DAN
. . . been meaning to post this for a while, much more time has passed than intended with some tuning adjustments made to my completely stock engine, with Solex no less! I discovered and fixed the original Solex intermittent idling problems shortly after my above quoted post was posted here, a ruptured secondary vacuum diaphragm.Just installed my 'one off' fabricated clutch fan and thought I'd post the fabrication dimensions, parts used and my reasons for bothering with this.
Mounted finished clutch fan assembly and road tested it. Initial results very positive . . . woohoo!! :yup:
And now for some 'seat of the pants' observations: my stock 1.9 automatic with 3.18 gear . . . floored standing start over same distance end speed:
1. Original stock single crank pulley, fixed 5-blade fan on water pump and stock alternator - 44 MPH
2. Dual crank pulley with alternator drive at same speed as stock and WP and fixed 5-blade fan overdriven by ~13% from larger front crank pulley - 42 MPH
3. Dual crank pulley with alternator drive at same speed as stock and WP and 5-blade asymetric clutch fan overdriven by ~13% from larger front crank pulley - 47 MPH
