Jim's right, you can use most any hard line, or high pressure rubber hose (normal fuel line will rupture due to pressure). The critical bits to have are the banjo fittings and bolts at the radiator itself. I recommend double clamping all junctions though, they tend to loosen and leak, probably due to temperature.
