1 - 20 of 63 Posts
· Opeler
I've searched this forum looking for signs that someone had an auto w/dealer installed A/C. I removed the center console to do some deep cleaning and found that a PO had used everything from screen door weatherstripping to duct tape to silicone in an effort to stop the air leaks from the ducting/spare tire deck to the actual vents. I've removed all the gunk and am now looking for ways to re-seal/re-create an A/C duct. Wondering if anyone else had this same set-up? I've also included a couple of pics of the gigantic, honking-huge A/C compressor they chose to use? Who needs that much compressor for such a little car??? A/C works like a champ and turns my GT into quite the icebox.
· Opeler
not actual hose
Jarrell, thanks for the help. But I don't have actual hoses that connect the A/C to the console vents. With my setup, the cool air comes from the cond/evap under the car and into my interior behind the seats/under the spare tire deck. From there, it's about a 3 x 7 inch opening that feeds directly into my center console, which is essentially a hollow console that the forced air is directed forward to the actual adjustable A/C vents. My A/C vents are located by driver/passenger leg, to the right of the shifter, and almost at the dash. I need to figure out how they initially kept the air in the console "tunnel" instead of pouring out every little opening (screw holes, shifter area, e-brake area, etc). Below is a picture where you should be able to see the vent at the driver's leg and one aimed for passenger face.
The 72 GT I got to replace my 71 had the same AC compressor and it works just like you said, it throws ice cubes at me. Mine did not have any ducting on the console, all I had was an open hole in between and behind the seats because there was no AC console in the car. To be honest with you, I do not plan to put in an AC console duct, just a regular front and rear console, all the air coming out of that one hole will turn the GT into a refrigerator in a very short time. I do plan on putting a louvered cover over the outlet though just for aesthetic appeal, I just don't like to have a gaping hole anywhere in the car and the louvered panle will direct the air flow upward to the roof and everyone knows cool air falls down, so that will serve a two-fold purpose. JMTCW.
· Senior Contributor
The A/C Consul did not come withany type of sealer other than a foam insusulation strip condensor unit and the case that was it. Also your Compressor is no the original that came from the factory, For the GT the same GM compreesor was used but it had a sticker on it that had Fridgedaire Opel GT and Model number thes was the GM dealer installed kit they also had a unit made by ARA which used a differeant type of compressor.
Quick question, looking at the pictures, was this original or dealer installed. When I looked at the compressor, I didn't see a sticker on it that had Fridgedaire Opel GT. Just curious as this was/is the first AC unit I'd seen in a GT. Thanks, Jarrell
· Super Moderator
Jarrell;
NONE of the Opels that were shipped here had factory a/c. All GT/Manta/Ascona a/c were dealer install or done by a sub-contractor (read custom installer)
Gene
Jarrell, that may be a rebuilt compressor, but it is a GM rotary type and is identical to the one that was on my GT before the fun and games started with the engine swap. IMHO, that setup is better than the ARA, only because it is a stand alone or stand off mounting and doesn't go to any other copmponent on the engine for support. The ARA uses the water pump bolts to hold it in place and can be a PITA to change the water pump. JMTCW.
· Member 1000 Post Club
Compressor Type
The compressors in the above pictures are the GM A-6. Meaning they are Axial 6 cylinder models. They were the work horse back in the 70's The R-4 came in the late 70' and into the 80's. The R-4 is a radial 4 cylinder. You can spot them because the are the flat or "pancake" looking. The displacement of the all A-6's were the same only the pulley style/type changed. There were some differences in the back plates too, some had different cutout switches.
· Super Moderator
Jarrell;
Another word of note, if the a/c unit you posted is one you have, it won't work if you do or have done the 5-spd conversion as the "tower" on the passenger side of the console won't allow the shifter to go int 5th. You'd have to get the other style console.
Gene
Gene, I am running the GM A/C Consul and my 5-speed works great, no problem with shifting at all, plenty of room. It is a matter of lay out when you modify the shifter or was that just an accident (not hardly I took it into consideration before making the final weld up ,LAYOUT IT'S A CARPENTERS' APPROACH :) ).
Rodney
My pictures? or the others? The pictures I have were of a Gt that a fellow had on Ebay a month or so ago.They were advertised as a "2 for one" sale When I talked to him and went to see the cars, we had met before. So I really couldn't bid on them. I'd never seen AC in a Gt and was interested in checking it out. Talk about even smaller!. I didn't realize the rear unit took up so much space!. I don't know if I would purchase them if they're offered, I have enough now. I still haven't gotten the one I bought New Years Eve. Somewhere this madness has to stop. ;) Jarrell
· Opeler
Discussion Starter · #16 ·
changed out consoles?
Namba, Is your 72 an auto? How does the two piece console fit with an auto transmission shifter? Fit okay? I'd like to do the same thing you are plan to do by about removing the center console altogether. But, I'd like to make sure I have some kind of console. What kind of louver cover are you planning on using?
Annette
· Opel Key Master
ara vs gm
Actually according to a Blitz poll the ARA setup was much nicer than the GM and worked better-basically GM tried to copy the ARA, even taking pictures at the factory. I wish they had an update to that article-many people have questions and need better pics....maybe that would be a good challenge for someone to update info and take complete pics of both setups???????
· Old Opeler
Good Challenge!
I have an automatic 1972 GT and have been collecting bits for an ARA type A/C unit for some time. The automatic uses the same centre console as the manual g/box but has a special low gear selection plate that fits under the shifter hole.
Here are some pictures of the ARA unit - complete out of the car and a nice shot of it installed - not pics of my setup but ones gleaned from here and there.
Jim, that's kinda interesting, none of those pics resembles what I've got in my GT. I'm referring to everything rear of the console, because mine didn't have a console when I got it. The AC fan and temp controls are at the outlet duct opening to the console way back between and behind the seats. It looks like it was designed that way because the temp sensor coil is there too attached to the control panel.
NedandTim, my GT only had the front half of the console when I got it, and it was a 4-speed manual tranny. I've got replacement non-AC console pieces to replace that and they will work just spiffy with the T-5 5-speed I'm putting in with the 3.4 V-6. The louver set-up will be from a warehouse hardware store (Home Depot, Lowes, etc.) and is mothing more than a furnace duct louver panel cut to fit the opening in the duct. I just want it to deflect the airflow up to the roof of the car and forward. When the AC was operating before, the airflow out of the duct was more than sufficient to hand the ice balls that come out of the unit. and turned the car into a referigator in minutes. HTH.
1 - 20 of 63 Posts
