Thanks Harold, saved me calling BS....
Gordo, some days your imagination is a magical thing...
You know, after numerous and frequent disparaging comments by you to me over the past 15 years PUBLICLY, which seems to be your moderating style, you have no idea how much I want to chew you out right now. But, as many of us have observed over the years, people that talk back to you get BANNED.
It's not BS and I can make that happen to any Opel right now. I have helped several people with this advice over the years. Gil will even acknowledge what I'm saying is true.
If you use a wrench or a pry bar or something to pry the alternator downwards to tighten a fan belt to keep it from squeaking, you CAN cause the pulley to skew to one side of the seal and the result is oil spray on your hood. I have done this at least 3 times in the 40 years I've been Opeling. Clean off the oil, relieve the tension on the belt, and the oil spray stops. Over tighten again and the oil spray comes back, loosen and it goes away again. I have seen this myself just as I described and I have given this advice to others and it fixed their problem.
Yes, Mr. BS'caller, if you way over tighten your fan belt it will eventually trash your water pump, but doing so can also cause oil spray on your hood. So, 2 bad things happen if you do that.
Your attitude towards things you've never experienced or heard of.......when it comes out of my mouth.......is appalling. But when RallyBob or someone you respect confirms it, you're suddenly silent with no apology for your demeaning "Gordo is a retarded clown" comments. Yes, this has happened a number of times over the years. I stay silent for fear of antagonizing the overlord. My patience is wearing thin.....
