Wow. We actually have a sub-category for "Linkage" threads.
The new stainless steel ball and socket linkage that we can now get from Splendid and OGTS(I guess) is just flat out awesome with improved adjustability, swivel pivots with bearings, removable balls, etc.
There is also "something" inside the sockets. Some kind of insert or bushing. I can't see precisely what it is, but it seems to be black plastic, possibly with roller bearings or something(I could be wrong about the bearing thing). It takes a fair bit of force to pop the ball of one rod into the socket of another, with the spring clip removed of course. The balls stay very firmly in the sockets, even without the spring clips, yet pivot very freely with no play. Sweet.
What are those inserts in the sockets?
Can I buy them?
Are they a patented proprietary product that just one company puts in their linkage?
I need a 4"-5" long, female/female(socket), adjustable linkage rod that has those inserts in the sockets.
I asked Norbert to look into this a bit and he found nice, new, short, linkage rods for me, but none of them specified or made any mention of inserts/bearing/bushings inside the sockets. Some offered "dust shields", which are just foam washers around the base of the balls that help dissuade debris from getting in. I don't need that.
I had to make an offset linkage connector gizmo to operate the side draft carb on my Steinmetz offset manifold and I used the linkage rod from my Mangoletsi throttle cable adapter contraption. That linkage rod is like any other common ball and socket set up and there's nothing inside the sockets, just the bare steel, just like oem GT linkage. The rod is subject to vibration and it rattles and has play in it. I don't like that. That can't be a good thing long term. None of the rest of the whole linkage system has rattle or play in the ball/sockets.
Can someone find or identify for me the cool kind of linkage that has inserts in the sockets?
Can I buy them?
