cable/fuel line routing
I didn't realize it would be such a long time between when I removed my motor and put one back in.....and I shouldn't trust much to memory anymore.....
There are three routing clips/holes attached to the engine and I'm not sure which is for what.
1. On top of the driver's side engine mount---is this for the battery cable?
2. On the Oil Pan bolt directly under the drivers side engine mount ---is this for the fuel line?
3. Holes thru the engine support/crossmember on the driver's side -- is this for the clutch cable?
Also.........I'm not sure what is stock and what's not.......but the fuel line coming to the carb from the tank is a nylon or plastic line nearly up to the engine compartment then some sort of thick rubber hose that has a pressed-on (?) clamp thingy where the rubber and plastic lines meet. If I want to replace this rubber hose do I need any special fitting or fuel line where it attaches to the nylon fuel line?
