1 - 6 of 6 Posts
Hi All- Clearing out surplus Opel Goodies: Vented Front Brake Rotors, 260mm (10.24") Diameter, 24mm (15/16") thick. These rotors are almost new, perfect condition!; Two Single-Piston, 52mm Ate Brake Calipers with hoses. These rotors bolt directly to your hubs with the original bolts. The calipers also are a direct Bolt-On to the Spindle. The 52mm piston is a significant increase in piston area compared to the original 48mm, and the extra diameter of the rotor will give you a noticeable improvement in braking torque. You may have to trim the backing or splash plates because the calipers are a bit longer than the original calipers. This setup comes with good, used! semi-metallic brake pads. Just make sure your rear brakes are in good shape. You'll never need more brake than this setup provides unless you're road racing...! $150 for all plus shipping. Will have more random parts for sale soon Ernie Bello
Solo II is fun in a GT!
I am interested also.
1 - 6 of 6 Posts
