1 - 2 of 2 Posts
· Premium Member
master cylinder too
Turns-out the master cylinder from a BMW 320i (1980 vintage) is a bolt on replacement for the one in my '71 Kadett. It doesn't have the tapped hole in the end for the triangle support to mount to, but the BMW had a different brace at the base of the master cylinder that does the same thing. It is also slightly larger bore, which makes for a bit stiffer pedal with a bit less travel, both of which I prefer.
· OPEL-LESS!!!
does the GT use the same booster and master cylinder as the Kadett? if so the next time i have probs with mine i will just convert as you have done. i have gotten in good with a local junkyard.....lol
1 - 2 of 2 Posts
