1 - 4 of 4 Posts
Looks good David. Did you attach the ends to the bumper attaching points? A few (lots), more pictures please and a description of how you made it. I'm hung up on the raising of both ends simultaneously and keeping the car level. Thanks, Jarrell
Opel Key Master
Rottiserie
I am using a pro unit that Wirly Gig makes. I would definitly recommend it. The problem with the fabricated one above is there doesn't seem to be a good way to balance it. You want to be able to spin in with very little effort-I am using a GT and if it is not balanced, (even stripped and light as it is) when spinning can cause the rottiserie to shift- or be too heavy for one man to bring back around. BE CAREFUL making a home built. I would be glad to post more info later on how the rottiserie works and what might be required to make it right....I found #1 is BALANCE. #2 strength #3 longevity
Keith
1 - 4 of 4 Posts
