· Life Long Opeler
HA HA
Ok, you've convinced me. Ill drop the front end. Im replacing the bolts for the control arms anyway. They are on backorder at gtsource. Besides, Im sure it will be so much easier to change out the boots on the ball joints and tie rods with the thing out too.
Speaking of front ends and brakes, I read that I shoudl NEVER take apart the calipers. Is this correct? And if so, why?
· Premium Member
calipers
They are no fun to put back together, no fun at all. I';; sick to starters, generators, and alternators, and let the professionals repair the hydraulic system that may see 3000# of pressure and that my life depand upon daily. I'm a little funny though.
The brake work you need to do might be easier with the front end out too.
I don't really trust myself opening up any brake lines either. I have a couple of guys who I have bleed and change my brake fluid. I don't mind changing pads and rotor or shoes and drums, but when it comes to hydralic fluid I'm the same way.
· Super Moderator
Yes, I've looked for new seals for the caliper halves. They're metric ID and OD, and are square-cut in cross-section (not round), plus they have to be able to withstand brake fluid. I've been able to find the correct size, but so far not the correct material. Off the record, I've rebuilt and split apart many calipers. I devised a method that, so far, has not leaked. One critical bit is the proper torque spec on the bolts retaining the halves....they are a stretch once-and-replace type bolt. I won't go into specifics on HOW to rebuild them using the old seals (liability rear it's ugly head), but it IS possible to do.
