Opel Manta A 1900ccRSS said:HI can anyone tel me if Front disk brakes from other Opel's fit on a GT. and if so whitch modell.
I believe the Kadett "A"s that came with front disc brakes used the same rotors and calipers as the GT (at least the 1.9 litre models; the 1.1 GT's had smaller bore calipers, so if there was a 1.1 Kadett with front disc's, it would have had the smaller caliper bores). The Ascona A used the same front disc's as the Manta (and 1900 GT), but both only up to 1974. The 1975 (and probably Ascona & Manta B, post 1975) had bigger front rotors, and calipers to fit (same calipers as the 1977 to 1979 BMW 320i). Not exactly interchangeable, but if you swap out the complete package (calipers and rotors), you end up with the "Big Brake" package, which is VERY desirable.fredopelgt said:Opel Manta A 1900cc
Not 100% sure but I think Manta B non-fuel injected![]()
David, I never said that BMW rotors would fit, just that the calipers are the same as the '75 and "B" models. What I was suggesting was to get the rotors and calipers from a Manta or Ascona B (readily available in Europe, where RSS is) and upgrade to the bigger brake package.nobody said:Sorry Keith I have a set of rotors and hubs from a 78 and the rotors need turned down to fit a GT, not in thickness but in diameter. The Hubs look good but the bearings are wrong in them. So to do the full BMW fronts it's best to have a lathe and some parts or just do the bigger calipers from a BMW and stock 75 brake rotors. JM2CW
