21 - 24 of 24 Posts
Is there a picture of this somewhere with the valve cover upside down so I can see how much and where the stainless-steel mesh goes (before I remove the valve cover)?
Finally got some pictures today. The square funky filter pad is a used stock unit and the stainless one is what many use to replace it.
To the OP:
  • Do you have any idea how many miles are on this engine?
  • How is your oil pressure now? Did you add some oil to the engine?
  • Is there any knocking or loud tapping sounds from the engine now?
  • Please take the air cleaner apart and see if there is oil in the air cleaner and if the air filter is soaked with oil.
  • Pull the spark plugs and see if they have oil all over them. That will tend to be a shiney black coloring.
It looks like the PCV valve in that hole was serving a function. Each PCV is a restriction of some amount and pulling that out removed the restriction and may have allowed a lot of oil to be pulled into the air intake. That could have burned up a lot of il and resulted in the oil pressure problem.
And, this setup may not be OK with this particular engine. Running the PCV setup incorrectly may be fine on a newer engine; the low level of blowby in a well rebuilt engine may be all sucked in quite adequately with a simple hose to the air cleaner. But a worn engine with a lot of blowby may suffer from excess oil into the air inlet, and leaking seals, without the proper setup.
Discussion Starter #23
To the OP:
Odometer says 69k, but that could be 1, or even 2. The car looks well kept and not rode hard. I would guess 169k but no way to know for sure.
Oil pressure got better after the oil change, but I think I have a fouled plug.. seems like it's missing. Got a backfire or two while starting sometimes. Going to the shop for a tuneup next Thursday.
I would say there's no knocking, but it's running rough I think because of a bad plug. Will find out next Thursday.
I'll look at the air cleaner because you may be right about the oil, since I removed the PCV valve for a 140 mile trip.
Not sure what to do to make sure I have the "proper setup". I'll have to wait until I get the tune-up.
Thanks for the info!
Discussion Starter #24
Took the air cleaner off and looked at the carb. Looks pretty good. No oil. Clean.
I'm positive I have a fouled plug due to all the oil coming out of the dip stick hole while driving back from Oregon.
I picked up a replacement boot for the dip stick on ebay for $15. So that problem is fixed.
429579
21 - 24 of 24 Posts
