1 - 7 of 7 Posts
What work and parts would it take to install a 2.0L C20XE engine with clutch in a stock 1972 GT?
Are there conversion parts to buy?
Is it an easy swap?
Are there issues with firewall clearance?
Would it bolt right onto the existing motor mounts?
Any clearance issues at the front end with fan, radiator, water pump, etc.?
Any other possible problems?
Thanks.
Your Noble Friend ;-)
It's been done before. Not an easy bolt-on, but absolutely easy. You will need:
  • C20XE (obviously) or a C20LET (been done as well)
  • Getrag 240 OHC-version (Manta B 1.8 or an early Omega A with OHC) - now these are pretty rare these days (German ebay)
  • Engine mounts (or make your own - not rocket science) and Oil pan with pickup tube from one of the above OHC engines (German ebay)
  • Custom exhaust header or make your own, plus exhaust piping (headers for other C20XE-converted RWD Opels are available in Germany, might need to be modified for a GT)
  • Enough energy to follow up with replacing everything in the cooling department. These engines need a closed pressurized system.
  • Cost (to get all this in the US) ~ $5k to $10k, depending on how much you do yourself.
  • Result: PRICELESS!!!
Dieter
PS: I have a Kadett B, Kadett C, and Rekord E with C20XE/RWD configuration.
With the C20XE clutch and Getrag 240, does the shifter still line up? I assume the motor mount has to attach to the body at the stock location.
Yes, the shifter lines up. Well. of course, the shifter bracket has to be shortened, the exact same way as when you put a CIH-Getrag behind a CIH. Of course, you will use the same Opel GT motor mounts.
Dieter
Opel Tinkerer and Rescuer
You need a 1.8L OHV RWD Getrag 240. I have a "kit" we are working on. I have found one of those and the C20XE.. 8045030249
1 - 7 of 7 Posts
