My project of adding factory fuel injection to my car is now at the stage where I need to come up with an idea for adding cable throttle to actuate the system. Charlie has suggested that I install a Lokar pedal and cable set up. He gave me a link to one, but I can't find it, so for now I'll have to go on guess work. I briefly looked at Lokar cable throttle set ups a few years back when I was starting with my side draft carb projects, so I'm somewhat familiar with them.
The problem for me is that I LIKE the GT gas pedal. It's been my friend for 40 years. I also have an auto tranny kick down cable that needs attaching somewhere. I also like the added bling of my stainless steel throttle linkage. If I remove the pedal and the linkage I'll have to mod away where the pedal goes through the firewall and throw the entire linkage system on the parts shelf. The arm that sticks out from the firewall to support the linkage near the pedal will also become useless. Charlie says that the oem pedal gets removed and the Lokar pedal assembly gets screwed to the floor boards, then I have to make a "pseudo firewall" to act as a cable housing stop.
This sounds dreadful.
Sure, it's easy enough to do, but I don't want to get rid of all the oem pedal stuff.
The only method I know of to attach cable throttle to the oem linkage is to weld a lever to the driver's side front-to-rear rod. Here's some pictures I took years ago when I was experimenting with modding the linkage for cable throttle. Something like this was suggested to me by OGTS and has been used by a number of people:
I can't weld, so I found a side draft actuating lever that I could clamp to the front-to-rear rod. I also experimented with reversing the rotation of that rod by having the vertical rod coming from the gas pedal attach from the engine side, instead of the opposite side it normally goes to. You normally weld the cable pulling lever to the front-to-rear rod so that it sticks out on the engine side of the rod. I didn't like that, so that's why I reversed things. This pic shows the result:
It actually worked just fine, but clamping, not welding, on the lever turned out not to work. No matter how tight I made it, it would eventually spin on the rod shaft. It needed to be welded on and stronger metal used. It was a one day project. A little more time and effort spent on it and it would have worked out just dandy. I could keep my kick down cable attached to the oem gas pedal arm and the project would have been done.
I will start off trying to replicate and refine this idea, unless you guys can give me some better alternatives.
Norbert, how has your friend made the cable throttle work for you and how did you keep the kick down cable working?
I welcome any ideas and advice you guys can give me, as well as, your experience with cable throttle set ups you have installed on your GT's.
:veryhappy
:veryhappy
