Checking the Transmission for Damage
Remove the ten slot headed bolts that hold the pan in place. When you drop the pan to drain the oil, watch for a spring and ball bearing (the reverse detent ball and spring) that is held up inside the side casting of the transmission. It is above the little round outward "jog" in the pan, on the passenger side. Don't lose them, or you will have created a new problem. And when you reinstall the pan, I like to coat the ball (which goes in first) and spring in grease to help hold them in place.
Check to see how much hypoid oil drains out (unless you have first checked the level through the side hole, and it was full). A full tranny will have 2 1/2 pints, which is bit more than a quart. If it was down a lot, that can cause a noisy trasmission, as well as serious internal damage.
Then, when you have the pan off, take a spray bottle filled with varsol and spray up inside the tranny, which will help clean off the residual hypoid oil and allow you to see better inside. Put it in neutral and have someone step on the clutch, so you can spin the gear sets while flushing it with the varsol (set an oil change pan below it to catch the drips, and watch your eyes!).
Look for obvious metal shrapnel in the pan (where it should be held in place by the magnet that is there). Also look up inside to see if there is obvious gear damage, specifically of the counter gear set (which is the single piece gear set with four different gears), and of the matching gears on the main shaft. Also look up inside the front of the main shaft, and see if you can see any sign of the front main bearing. On Katheryn McCoy's transmission, which makes a sound much like Kate has described (hmmm, coincidence? Maybe not!), the front bearing had eaten it's "shield", and the remaining parts could be seen floating around in front of the drive gear.
Also look for signs of small pieces of what may have once been needle bearings. It is very possible that the "rattle" is actually a "grinding", caused by the needle bearings in the counter gear or the main shaft. You might also drop the drive shaft while you are there to ensure that the PO (Previous Owner) didn't forget to install the thrust spring, which can cause the driveshaft to rattle.
When you go to put it all back together, remember to clean the old gasket off well (unless it comes off clean), and also to flatten the dimples in the pan where the bolt holes are. Otherwise it will leak (even with a new gasket, or even volumes of RTV sealer) between the bolts. And make sure that the four bolts that attach the tranny to the bell housing are tight; if they are loose, that can cause a rattle, and worse will cause the tranny oil to leak out.
If you decide to get more serious, such as actually dropping the tranny to either more completely inspect it or even rebuild it, make sure you have a factory service manual, and not just some aftermarket version. This is a very easy transmission to rebuild, although the parts can get expensive if there is too much to do. And even if you get a good used trany, you might be advised to replace at least the worn synchro rings (typically second and third) to get the best possible transmission for Kate's "original" Opel.
HTH, and good luck!
