newman try a different brand or weight. I run 80/90 in all my manual trans cars with the exception of my Subaru due to having a rather expensive center diff inside. I always use Castrol brand in daily drivers. HTH
Thanks for the suggestions! Shifting was easier this morning but then again the temps are rising back up here in Atlanta so that probably explains it...It will shift better with a GL-4 lube in it. The brass parts inside the transmission will last longer too. It takes some effort to find GL-4 80-90 sometimes, but it is out there. All older transmisions work better with something other than GL-5
Tom
Matt
