Yes sir it is.Excuse me rally Bob, is this my Manta from 1989?
The casters I have are MASSIVELY overkill for an Opel. They’re rated at 600 lbs each, with 6” diameter urethane wheels. That works out to 2400 lbs capacity per rotisserie stand, or 4800 lbs total capacity for two stands. Seeing how the stripped body shell is about 500-600 lbs, I’m not stressing the casters at all!There's a local metal supply shop that has a 'bargain barn' loaded with cutoff pieces. I'm going there this weekend to get enough metal to build the rotisserie.
What weight capacity do you think the casters should be rated for?
Exactly for this reason. I used what I had on hand. My first one I built from mostly 2” x 2” x .095” steel tubing.Looking at your original vs the new one, the new one looks more robust. The angled supports were angle iron, but are now box tubing. Was that more because it was the metal you had available or did you think it needed more support?
You could rotate a '65 Caddy on there with all the running gear still in it. That's a hellova strong stand!Exactly for this reason. I used what I had on hand. My first one I built from mostly 2” x 2” x .095” steel tubing.
The new one I built from 3” x 3” x .187” steel tubing because it’s what I have left over from a custom corporate meeting desk (21’ x 42’ long!) I built for my father’s company about 30 years ago.
A'65 Caddy probably too wide. The stands would likely be alot taller.You could rotate a '65 Caddy on there with all the running gear still in it. That's a hellova strong stand!
Uh .... I was just kiddingA'65 Caddy probably too wide. The stands would likely be alot taller.
Maybe…maybe not!A'65 Caddy probably too wide. The stands would likely be alot taller.
I know.Uh .... I was just kidding![]()
I’ve never bought from Logan Steel though I’ve seen their billboards for years when I lived in CT. I was fortunate that where I lived in CT (Pleasant Valley in Litchfield County) I had a local welding supply/steel supply shop about a mile down the road from me.I picked up a few 8 foot lengths of 2x2 steel. I got them at Logan Steel in Meriden, CT if anyone is ever looking for metal, they have a Bargain Barn full of cutoffs and misc metal pieces. You pay by the pound, great place.
They didn't have any pipe combination that would work for the rotating part. I was thinking, I have 2 old front wheel hubs from a late 90's ford explorer. Do you think that could be used for the rotating mechanism? They support at least 1000 pounds each in an unloaded Explorer. In my head it's similar loading geometry, think of the rotating Opel as the Explorer and the stands as the wheels.
