1 - 12 of 12 Posts
· boomerang opeler
with just the head you would need diesel block to do the full copy of the 16 vavle manta rally engine and would get you something in the area of 160 bhp but is it easyer ??? you would have a lot of work as its a cross flow (the opposite of the cih engine ) you would be making your own exaust and may have problems finding things like an inlet manifold
the rest is OK
but you can do all this easy with a 2.4 frontera motor it will bolt straght up to the box and you only have to use the frontera front pipe to make it match the gt exaust then a new inlet manifold for carbs
· boomerang opeler
4 or 5 speed whichever you want most people want to use the 5 with it to get the extra milage that the overdrive top gear gives
didn't know that... so i can get a 2.4 with carbs first... and later on get the gertrag and driveshaft... and then later on... tune the 2.4 a bit... spreading money is what i call it :p
· Super Moderator
carb manifold for 2.2/2.4 CIH raised-port heads
As far as I know, the 2.4 CIH was never offered with carbs, so no "stock" carb manifolds for raised port 2.2/2.4 heads. :(
As Baz rightly said:
baz said:
. . . and may have problems finding things like an inlet manifold
the rest is OK
but you can do all this easy with a 2.4 frontera motor it will bolt straight up to the box and you only have to use the frontera front pipe to make it match the gt exhaust then a new inlet manifold for carbs
:eek:
· Premium Member
tekenaar said:
As far as I know, the 2.4 CIH was never offered with carbs, so no carb manifold for raised port 2.2/2.4 heads. :(
There was a set of Weber manifolds for the 2.2/2.4 on e-bay Germany the other day. Seems to me they went pretty reasonable too, something like 175 euro, without the carbs. Thought long and hard about them for my own 2.2 head, but that's basicly the cost of a megasquirt, and put like that the decision for EFI was easy.
· Opeler
An inlet manifold for twin Weber DCOE/Dellorto Side draught carbs to fit the 2.4 CIH head is now available from Mangoletsi in the UK. It should also fit the 2.2 CIH head, which also has raised ports.
Motoscope in North Yorkshire are a distributor for Mangoletsi Manifolds.
Motoscope (Northallerton) Ltd
Standard Way Industrial Estate
Northallerton
North Yorkshire
DL6 2XE
England
Tel: +44 (0)1609 780155
Fax: +44 (0)1609 780062
Email: [email protected]
WWW: http://www.motoscope.co.uk
Opening Hours: 0900-1800 GMT Mon-Fri
0900-1630 GMT Sat
Hope this helps,
Dave Jackson
this is a custom fabricated head with no attachments.
this conversion is done by some poeple over here but is is extremely expensive te buid this motor by yourself (if you do it right that is :))
cost are around 15.000 euro
risse motorsports also delevers this setup and prices are around 20.000 euro!
1 - 12 of 12 Posts
