21 - 23 of 23 Posts
You shouldn't have any issues finding a good 2.2 double groove, maybe even a single groove pulley with the HB. Again, if it is questionable, it can be rebuilt.
Keith, how would one find one?
no longer available. So sounds like a dead end here.
Does anyone have the dimensions of the stock pulley ID and OD of the part that inserts over the crankshaft. I'm wondering if there is something close aftermarket that could be modified with a little machine work. We don't need a "balancer" but rather a "damper" pulley.
Something like this: 62 77 Ford 200 3 Bolt Hub Single V with ACC pulley Damper harmonic balancer | eBay
Many dampers/balancers out there that might be candidates even if the hub needs some machining which I would think most machine shops could do on a lathe.
21 - 23 of 23 Posts
