? coil, pertronix
I have a internal resistor coil which reads about 3 ohms between the + and - terminals, this I believe is normal. However, when I read between the coil output and either the + or - terminal, I get a reading of about 13.5K ohms. Is this normal? If not, what kind of a reading should I get? Also, is there any way to check a Pertronix electronic ingnition with an ohm meter? Any help would be appreciated.
Jim
Jim
