There are threads on the inside that I can not see, right? I would not assume the bolt would just slide through....
OGTS has them listed as Part #3018 -- $15.00 .. in November, 2002davegt27 said:i would get new ones first just to be on the safe side
now if i could only remember where we got the replacement bolts
Davegt27
What about my case? Do I dare try this option? Let me know!baz said:here is 1 thing you may never think of unless your a blacksmith
shock horror WATER![]()
heat up the bush to a dull red and then quench it with water
the rapid cooling will break the bond that rust has formed inside the bush and you should be able to punch it out
all those years when we thought water is our enemy and it turns out to be a friend![]()
i have done this on lots of frozen bolts and it works a treat
any high strenth bolt should be replaced after heating as it changes its metalergical properties when quenched
mild steel is not effected to any real extent as you can not temper it
