1 - 20 of 20 Posts
After going awhile with no high beam headlights then running just one headlight on my 73 GT, I figured it was time to rewire my headlights.
I bought a new headlight wiring harness from Keith Lundholm. Well worth the price! Professionally done.
Anyway, after pulling the old harness out, this is what I found! :shocked::yikes: Fire waiting to happen. I know this subject has been talked about a lot, but the proof is in the pudding! Change yours if you haven't already! I probably waited longer than I should have.
What's a Nopel?
Agreed. Well worth the effort. That happened to me during my build & the wires crumbled/disintegrated in my hands.
But I wasn't as lucky as you because Keith wasn't in the harness building world yet and bought a harness through Splendid parts. Professional quality, but every instruction was in German. However, it took me 3x longer to translate the instructions than the install of the harness!
Discussion Starter #4 (Edited)
Just in time.... Let us know how much time and effort installing the new harness takes you.
Not done yet but its taken a good 4 days work, spread out over a couple of weeks. I took the mechanisms out and cleaned them up, replaced the micro switches, greased the rotating joints with white lithium grease, etc. So, it's taking probably longer than it should but I'm taking my time and trying to do it the right way. While I'm in there, may as well fix stuff!
Discussion Starter #5
Marc, I am lucky that Keith makes them now. I guess I could have made a new one myself but that would have been a pain in the ole butt. I saved a lot of time by just buying the harness.
Keith's headlight harness goes all the way back to the fuse box under the dash. No splicing. BUT, it's one royal pain in the ass to fish the wires through the fuse box. I cut the old wires off at the firewall and used those wires to pull the new ones to the right terminal connections on the fuse box. I just matched up the correct new wires as the are color coded the same as the old ones. I did have to unbolt the fuse box and drop it down but that's no big deal.
Also, while I was in there, I found a couple of bad spade connections. The connecters had become brittle and broke and were loose so I just replaced them with new ones. It was a tight space but I got it done.
I also removed the drivers seat so I could lay on my back the best I could while working on it.
Discussion Starter #7
Discussion Starter #10
Here we go! I've got all the wiring completed and worked a few bugs out. BUT... The white dash light, which comes on when the headlights are not locked in place, comes on when the headlights buckets are locked in the down position. :thinking:
New wiring, new micro switches... I'm thinking I wired a micro switch wrong which I believe is on the passenger side. This is a 73 GT...
Do you have a wiring diagram? I think you are correct on the passengers side switch. I need to look at my wiring diagram which is down at the Shed to be certain. I can look now if you need it tonite. I'm through for the day. Jarrell
Opel Key Master
Three wires for the passenger side switch, White/yellow goes on N.O, brown on N.C., gray/green on C
Driver side micro switch left hand side looking at the back of the mechanism Red/Black go on N.C., Brown/Black go on C
These mean
Normally Open
Normally Closed
Common
The switches will have these markings on them
These mean
Normally Open
Normally Closed
Common
73 Fsm shows starting at Rt side headlamp, (12Brown, 12 white,12 yellow.) Main headlights
12 brown is ground, attached to Headlamp indicator switch (micro?),Passenger side 2 wires from micro 1 12wht/yel goes into Headlamp relay. The other side of the same switch, 12 Gray/grn runs back to Headlamp Ind 1 side, other 12 brown /Blk runs to Green plug in, runs 18 brown/blk to drivers side Headlamp ind switch, comes out as 18 blk/ red, runs to 15 amp fuse, 3rd from right on fuse block. Hth Jarrell
Discussion Starter #14
Found the problem. At the fuse box, I guess I was messing with it so much, one of the hot lead spade connectors had come loose. Needle in a hay stack!
One of the spade connectors wasn’t seated properly in the plug but I would have never found it without help from Soybean. Inspiration! It really was like a needle in a haystack. Whew!
Now on to figure out why the white dash light is on when the headlights are locked down... ?
You got instructions ?
I only got the loom in the box...no instructions...I tried to install the looms in the new fuze box as they came out..but it still looks like a rats nest...I installed it but plan on taking it out and seeing if I can clean up the jumble of wires.,.
I wish I took better notes as to the location of the wire looms...I am having trouble getting them in the correct places...over, under or thru...
Joel
Opel Key Master
Roy, if you don’t care about the white light feature, you can disconnect the Red/Black wire or even the Gray/Green wire that connects to the dash. I personally don’t even run that circuit in our cars because I think it is stupid. I need an indicator light to tell me my headlights didn’t turn on?
Most of the wiring goes to the rear relays of the fuse box. The white jumper from the headlights goes into a connector, and the Brown/Black wire goes into another connector as well. You have the brake master cylinder switch too that will go into a box connector. The micro switch wiring is downsized from 12 gauge that is not needed and helps immensely with routing and installing the harness.
The only thing I can’t do to make it easy is install it for you. I’ve been running this harness for 10 years in multiple restorations, but never said it is easy to do without some experience.
Discussion Starter #19
Keith... I’m not complaining at all! I knew it was going to be a pain before I even started. I think that’s why I kept putting it off for so long. Hell, I’m happy just because you made the harness and not me! It’s just one of those things... There is a sense of satisfaction of getting it all working again. Needed to be done. Not sure I’d want to do another one but if I did, it would be easier as I know now better what to do.
If I can’t get the white light to do what it’s supposed to do, I’ll take your advice and disconnect it.
Thanks for the tips! The harness was well made.
Discussion Starter #20
Found the reason the headlight indicator light on the dash was on when the headlights were in a locked position. The light should be on when the headlight buckets are not locked either up or down. On the drivers side, the outer micro switch was hooked up wrong. Had one of the connections on the wrong terminal. My bad....
But little bugs are expected to be worked out due to human error (me ?).
Everything is finally working again as if the car was new! Thanks Keith for the harness. Worked out great.
1 - 20 of 20 Posts
