Finding TDC
The way I do it is this:
Remove the sparkplug from piston #1 (the front of the engine facing forward) and place a thin screwdriver inside the plug hole resting on the piston head. Rotate the crank with the fan (you can remove all plugs to remove the compression and make this easy.) until the rotor on the distributor points at roughly the 4 o'clock position. At this point the piston should be near the top of its stroke. You'll know this by the screwdriver pivoting up (or down). Rock the fan until the screwdriver pivots it it's highest point. CAUTION: remember the piston will goto TDC TWICE. Once at around 4 o'clock and then again at around the 10 o'clock position. You'll be 180 out if you adjust at the 10 o'clock.
Did I make this more confusing now?
Good luck! (I have the XR700 also.)
-Kyle
-Kyle
