1 - 6 of 6 Posts
· opel assimilated
Okay, time to pick the collective opel mind. I just installed the crane ignition settup in my car last night, and lo and behold.....it wont start. I did everything as it said, but it just wont fire. I do get spark from the coil to the distributor, but not from the distributor to the plugs. Any Ideas? The box has an led light to let you know it should be firing and it is working, I am just stumped. Help please. Oh! I also installed a 65 amp alternater at the same time(if that matters).
· opel assimilated
Discussion Starter · #2 ·
the cap and rotor were installed about 6 months ago and has about 5000 miles on them. they worked 2 days ago, but not now. do you think it could be the cap and rotor?
· Senior Contributor
Make sure that the pick-up is not touching the rotor and the rotor is pushed down all the way. If you had the distributor out and fitted the pick-up with it out of the car it will drop down if you held it by the housing and not the shaft when you fitted it.
Pull your cap and make sure it is A. Not touching and B. not to low which is what I am guessing is your problem.
Calvin
PS Also make sure that no light is getting in the distbutor cuase when I removed my vaccum advance and didn't cover the hole I had the same problem.
· opel assimilated
ok, here is what I did. I left the dist. in the car, lined the rotor with the #1 cylinder mark on my dist(4 oclock) then i took out the points and the condensor. then i put the modulator and the mount and shutter in and alligned it like it said to in the manual. do you think the shutter made the rotor stick up higher? is that what you mean calvin? Another ?, is this unit supposed to take away the vacuum advance? thanks
I built a Legere 2.4 so I had to remove my vac advance.
if you had the distibutor out, which to install the molex you must of. if you held it by the housing to install and check the pick-up when you put it back the housing falls as it rises up a bit on the shaft if you hold it by the housing. When you put the distrib back the housing falls about 1/8 of an inch which makes a big difference.
Try this. take a 19mm wrench to the front pully bolt and crank it around till the pointer and the ball on the fly wheel line up. That is top dead center (TDC).The rotor should be pointing about 4 o'clock if 12 is the part closest to the motor. Redo your pick-up placement with the distrib in the car. (Make sure the plugs are 1 3 4 2) and try to start it. If it doesn't go switch the 1 and the 3 and the 2 and the 4 plugs and TRY AGAIN. If it starts shut it off reline the pointer ball on the flywheel so the car is at TDC and the rotor points to about 4 o'clock. Pull the fuel pump and lift the distrib carefully out and rotate the shaft 180 replace the fuel pump and it should start.
1 - 6 of 6 Posts
