Crank Diameter?
1769 Views 5 Replies 4 Participants Last post by  kwilford
A few years ago I replaced the front engine crankshaft seal, apparently without much luck as, I suspect, there is an amount of wear on the crankshaft. Does anyone have a recommendation as to the inside diameter of a Speedi Sleeve that might fit the bill?
1 - 6 of 6 Posts
The front seal rides on the crankshaft pulley, not the crank itself.
Just replace the pulley.
Reactions: 1
Even better information. Thanks
Reactions: 1
If a new (or un-grooved) pulley isn't available, the repair sleeve is also off the shelf at most auto stores. I don't have the Fel-Pro part # handy, but if you take a pulley in, the correct sleeve can be easily sized. My notes say the size is 45 mm ID, 24 mm long.
And IMHO, a sleeved-repaired pulley may be better than a stock pulley, as the sleeve is very smooth, and seals last longer when running on a sleeve than on a machined pulley journal.
Here is the OGTS listing:
1 - 6 of 6 Posts
