Hi all,
My crank pulley has some pitting that I believe is causing an oil leak at the front seal.
So I bought one of the OGTS repair sleeves and attempted to install it. I thought that the sleeve needed to be driven all the way down to the "step" at the base of the machined surface. So after tapping it on as far as I could with a wooden block, I tried a variety of implements and ended up making a horrible mess of it:
I searched the forums here for advice and found this one, in which a couple of the posters mention that they didn't drive the sleeve all the way down:
www.opelgt.com
However, I couldn't find any confirmation whether or not these "partially seated" sleeves worked. It looks to me like the witness marks from the seal on my pulley would be past those sleeves, so I figured that wouldn't be far enough to get the job done
I suppose ideally I'd like to find a nice replacement pulley but can anyone offer additional insight on how far down these sleeves need to go if I try that route again?
Thx - Bob The Destroyer
front leak causes?
If I remember correctly, the engine rotates such that you can loosen the pulley bolt using the correct socket and a breaker bar and just hit the starter motor for a second. You have to place the end of the breaker bar on the ground to the right of the pulley. Make sure you check engine...
