Sorry, Bob, I guess I didn't mean it "can't work" because you know it does! I should have worded it more like "there's gotta be a better way to drain the oil and feed the cam to begin with". In studying the oiling system and reading your posts it just seemed to be impossible to supply enough oil to the lifter galley through that dinky little feed passage. In carefully tearing down my (now) three 1.9s, I notice that the front lifters show no wear but this worsens steadily all the way back to the rear lifter faces being absolutely SHOT. In all three engines!
So to make a short story long I drilled out the plugs above the cam bearings, tapped the holes to 1/8" pipe. Then got four 1/8 npt x 1/4 tube compression 90 degree elbows. Into the 1/8 npt end I soldered some 3/16 or 1/8 inch (I don't remember which) steel tubes about 2" long, they almost reach the cam journal when the fitting is screwed in. Now from the compression fitting end of said 90 degree fittings run some 1/4" steel lines very carefully (painstakingly, believe me) run to that center hole in the head that happens to be just above that square shaped cover coming out of the left side center of the head. (What's that for, anyway?) All four tubes come together right at that plate and braze together inside a 3/8 pipe fitting which then pokes through the cover, sealed with good old "right stuff" and O-rings. I call this tubing gizmo the "oil header" because it looks like a miniature shortie V8 exhaust header. It all easily comes in and out of the head at will. Anyway it all then externally ends up being a 3/8 tee, one branch is hosed to the main oil galley tap at the lower right side of block where there is also a tee fitting. I used tees so we could hook the oil pressure gauge to different areas during testing, wanting to ensure I wasn't bleeding off too much oil from the crankshaft! And now that we're using a "big"Honda Accordian radiator w/ trans oil cooler, I just might run the cam feed oil thru it first... Anyway, that's how I oil my head. Seems to work, haven't blown anything up YET but sure gulped a lot of oil out the valve cover vent the first time out. Yup, the stock valve cover did NOT work in a hard left turn. But that's a whole nuther story...
