Here's my thoughts and what I discovered from paint chip repair on YouTube videos(Another source of information about various car things you might also consider).:
Paint chip repair generally requires multiple dabs of VERY precisely applied drops of touch up paint until you have built up the chipped area to at least the height of the existing paint, if not above. Then, if you insist upon absolutely smooth undetectable perfection you need to do laborious very fine sanding/buffing and maybe use of a clay bar. Less perfection is up to you.
Spray paints, and air brushing also, are generally inferior to brush on paints, because they need thinning fluids added to them to make them sprayable and they don't cure properly and can run easily as a result.
From my personal experience, finding touch up paint that exactly matches my car is a PIA. If I did the whole polishing and sanding thing they would probably not be noticable, but I don't so they are.
