1 - 3 of 3 Posts
I need to replace the front suspension crossmember and leaf spring on my '71 GT. I believe that they are the same on all the GT's. If not, what years can I use?
Jim
Believe they're all the same with the exception of the ones used in the 1.1 GTs, fewer spring leafs (2 vs. 3) and smaller brakes (caliper pistons)?
1000 Post Club
All 1.9 L GT suspensions should bolt up. I know there is a difference in control arm bushings on some of the years(you will need to know what year the suspension unit is out of if you want to change or modify the bushings). Other people on the site probably know which bushings go on which year.
1 - 3 of 3 Posts
