How do I disconnect the linkage from the carb? I don't even know if I am using the right words. It looks like a ball and socket joint that is attached to a threaded 11 mm nut. Do I just unbolt that socket?
. . . and here it is diagrammatically:Working from the carb to the pedal linkage.
What Weber do you have? The DG series (eg DGAV, DGEV, DGAS: the correct ones for an Opel) has the primary throat (and linkage connection) outboard (same as the stock Solex, near the fender) so the linkage rod should line up straight on to the carb. No reason to "...adjust the peg holder thingy..." whatver THAT is2) we have a weber carb. it appears the linkage will slide right in and work OK however, it is off a bit. Is it ok to loosen the "peg holder thingy" and move it around the center???
By your description, I was afraid of that. In spite of the warnings I gave, a DFAV (properly jetted) can be a reasonable fit. I had a DFAV (from a Cortina GT) on my wife's old (late, as in deceased) Opel GT, and a DFM (the manual choke model) on my GT (for about 50,000 miles), and both worked very well. Well, at least ten times better than the Solex on either car. I have since acquired a DP 100 (the manual choke 38 DGAS) but the engine is in parts. And so is the car, but THAT'S another story.I do have the improper carb DFAV that rotates in the wrong direction. I purchased this carb from a follow member here on OpelGt.com trusting it would work well. Does anyone have any suggestions on how to convert the linkage, if not damaging to the engine or carb, and or if the individual will not refund the money how should I list the part on ebay and for how much?
Thank You, Joshua
. . . recommended solution!By your description, I was afraid of that. In spite of the warnings I gave, a DFAV (properly jetted) can be a reasonable fit. I had a DFAV (from a Cortina GT) on my wife's old (late, as in deceased) Opel GT, and a DFM (the manual choke model) on my GT (for about 50,000 miles), and both worked very well. Well, at least ten times better than the Solex on either car. I have since acquired a DP 100 (the manual choke 38 DGAS) but the engine is in parts. And so is the car, but THAT'S another story.
It was years ago when I installed those DF carbs, . . . , but it's been twenty years!
The second trick was . . . pretty much screwed for future use on a proper carb.
Or you could sell it on eBay (probably get $100 or more) and buy a proper DG Weber.
HTH and good luck
