1 - 3 of 3 Posts
· Super Moderator
Here is a listing of US-spec distributor advance limits for 1.9 litre engines. One item worth noting is that automatic-equipped versions of these model year Opels had different advance rates (the advance occurred sooner), which was accomplished by using lighter tension springs on the mechanical advance. This was to help improve acceleration. Part numbers for the distributors for automatic-equipped cars were different than the same-year manual-equipped cars, but they were otherwise identical in operation. Except for 1975 Opels, all US-spec 1.9's had the static (idle) timing set to 0 degrees BTDC (before top dead center). Note that the engines had less and less total timing as the years progressed, in the interest of reducing exhaust emissions. Opel 1.9 litre engines tend to make the most power with a total timing figure of between 34-36 degrees.
1968 - 32-36.5 mechanical advance
19.5-22.5 vacuum advance
51.5-59 degrees total
1969 - 32-36 mechanical advance
11.5-14.5 vacuum
43.5-50.5 degrees total
1970 - 32-36 mechanical advance
11.5-14.5 vacuum
1971 - 28-32 mechanical advance
7-10 vacuum
35-42 degrees total
1972 - 28-32 mechanical advance
7-10 vacuum
35-42 degrees total
1973 - 28-32 mechanical advance
1-5 vacuum
29-37 degrees total
1974 - 28-32 mechanical advance
1-3 vacuum
29-35 degrees total
1975 - 25 mechanical advance
5 degrees static timing
no vacuum advance unit
30 degrees total
Reactions: Willhud
Stock Bosch Distributor Numbers
Bosch distributor housing numbers
1.1
1966-67.................150 003
1968......................150 006
1969(to6/69)...........167 004
1969(after6/69).......167 023
1970......................167 009
1971......................167 004
1.5
1968......................167 001
1.9
1968.............................167 001
1969(mtrans to6/69)........167 005
1969(atrans to6/69).........167 006
1969(all after 6/69)..........167 024
1970-71.........................167 007
1972 mtrans....................176 012
1972 atrans.....................176 011
1973..............................176 012
1974..............................176 012
1975..............................170 140
· Someone here finds me offensive
73 GT 1.9 manual fire glow orange drivetrain trimmed in dark metallic copper over satin black yippie
BUMP just incase it was forgotten or needs to be added to existing
1 - 3 of 3 Posts
