OOPS there was a mistake in my aftercooler/intercooler explanation!
Thanks for catching that, Dave.
An intercooler is the air to water heat exchanger. The Cummins and Detroit coolers that are hidden in or under the intake are intercoolers.
The aftercoolers need a whole bunch of airflow to be effective, I've only seen them up front, usually forward of the radiator but sometimes lower and off to the side, but still where a lot of air is flowing through.
Both types of coolers have really small, fine finning and tiny passages compared to even a radiator. A trans cooler is a big tube going back and forth through much larger dissipation fins. Huge difference, when you look closely at how they work.
You could go to any truck shop and see a big pile of massive aftercoolers in the junk pile, they are the part destroyed right after the grille and before the radiator when the deer goes through at 65 miles per hour.
That utility pump is still only moving 4 gpm. Bilge water is not warm. Self priming suggests to me it is a rubber impeller.
Your pump has to move a bunch of water, there is no need to lift it much, just increase flow. Can a moderator fix my mistakes in the previous post, so as not to confuse anyone else again?
This pump is in the Grainger catalog, 1080 gph, 180 degree liquid temp.
