If they are telling the truth, 150 lumens will light up an engine compartment almost like daylight, sans shadows.
Are you sure about that?Under the car lighting is illegal to drive around with here in Jersey, so they can only be used when parked at evening Cruise-ins, Carlisle parking lot gatherings, and as a quick show off thing for my friends, family, and neighbors.
White or amber appear to be legal.NJSA 39:3-50. Color of lights,
All lamps and reflectors, which display a light visible from directly in front of a vehicle as authorized by this subtitle, shall exhibit lights substantially white, yellow or amber in color.
(a) The color of light emitted or reflected by exterior lamps or reflectors on a vehicle shall be as follows, except as otherwise provided in paragraph (b), (c) and (d) of this section:
White when the lamp is a headlamp, or spot lamp, or illuminates a license plate or a destination sign; or is located on the outside limit of a side car or other attachment on a motor cycle;
Substantially white or amber when the lamp is a side-cowl or fender lamp, running-board or other courtesy lamp, front parking lamp, back-up lamp, auxiliary driving lamp; or a turn signal on or facing the front;
Substantially red or amber when the lamp is a turn signal or a stop lamp on or facing the rear;
Red when any other lamp or any reflector is on the rear or on either side at or near the rear, except as otherwise provided in paragraph (f) of section 39:3-61 for a combination marker lamp;
Amber when any other lamp or reflector is on the front or on either side other than at or near the rear.
(b) Lamps and reflectors on projecting loads shall emit or reflect light with color as provided in section 10 of this act.
(c) No person shall drive or move any vehicle or equipment upon any street or highway equipped with any device or lamp thereon capable of or displaying a light of any other color than permitted by this section, except: an authorized emergency vehicle, an authorized school bus, or a vehicle authorized by a permit issued by the director.
(d) A permit authorizing a vehicle to be equipped with a lamp capable of or displaying a flashing light, except as provided in 39:3-54 or a light of a color other than permitted by this section, visible from directly in front of said vehicle, may be issued by the director when necessary, in his discretion, for the reasonable and safe movement of traffic. The permit shall specify the type and color of such lamp and the conditions under which a person may drive or move the vehicle with said lamp displaying a light. The permit shall be valid only when the specifications and conditions contained therein are complied with.
The director may cancel or revoke a permit issued under authority of this section whenever the conditions for its issuance no longer exist or on any other reasonable grounds.
So, what are you going to do at daytime car shows? Add a 1000 W halogen spot light where the battery sits?I installed the V-pattern metal strips for the front lights today and I was going to call it a day when I figured I would spend a little time figuring out how to light up the engine compartment.
WOWOWIE!
It turned out REALLY great. WAY better than I had hoped for!
Here's a video. Eat your heart out with envy........
https://youtu.be/d2uA5TZTFmc
