Factory Upgrade
IN 1979 Opel (and Vauxhall in UK) upgraded their 1.9L motor to 2.0L by increasing the bore to 95mm (3.74"). Standard 2.0L pistons are available from
www.opelgtsource.com
Since the bore is very close to the standard 3.750" of the 265 Chevrolet motor and the piston pin height very similar, pistons for this engine are often used for a 1.9L to 2.0L conversion. There are obstacles to overcome such as the Chevrolet pin size being a larger 0.927" (23.56mm). Custom hi-performance pistons are available quite easily for the Chevy motor too and can be sourced with smaller (Ford!) pins at 0.912" (23.16mm) but these are still slightly bigger than the standard Opel pins which are 23mm even.
Later Opel/Vauxhall increased the size of the motor to 2.2 L by using a longer stroke crankshaft and finally reached 2.4L with yet another increase in stoke but both still with the 95mm bore. The external dimensions of all the motors from 1.5L through to 2.4L are similar and have the same bolt patterns for bellhousing. head and front cover - so all the parts can be interchanged with appropriate modifications.
These motors are known as Cam-In-Head (CIH) Opel motors due to the unique positioning of the camshaft. There are also six cylinder versions used in larger Opel/Vauxhall cars too. If you enter "Opel CIH" in your web search engine it should find some interesting information - particularly conversions done by David Jackson in the UK. Worth a look!
