21 - 30 of 30 Posts
Kevin - I looked at the ATE catalog and did not see any M/C kits listed. I wonder if regulations in Europe prevent rebuilding them?
You can order a rebuild kit for an 105 Series Alfa Romeo Spider in the UK and since regulations on stuff like this tends to be fairly uniform across the EU/EEC I doubt it's prohibited
BR011/1 BRAKE MASTER CYLINDER REPAIR KIT 20mm ATE - Classic Alfa
That equals 30 dollars more or less, a new MC for the same car is 80 dollars and rebuilt ones probably somewhere in the middle and most brands have a very good exchange program for these things so perhaps there isn't enough demand for certain models to make them available for general sale ?
need your help
Kevin,
before you do that, think about an Opel 3.0-24V from Germany. 204HP, straight-six, and this motor will last forever. It is a straight swap with your current engine, and takes less gas. You will still have an Opel engine. I'll be happy to assist you with getting one from Germany.
Dieter
hi, i am wondering how much it would cost for the engine? i would love to have one.
Opel Tinkerer and Rescuer
Just got confirmation that #491 is still alive and well as is the owner..
Reactions: kevinfier
The factory tachometer can be retained with any pre-07 V8 OBD2 GM swap. The tach resolution (tach output) can be adjusted infinitely to an acceptable range of accuracy. I have done quite a few LS series engine swaps over the last few years and have built 30-40 harnesses on the side. If you need any help with wiring or pcm tuning, please let me know. I am happy to help!
Opel Adventure # 77 NC
Discussion Starter · #26 ·
Hey GS20,
Have about 8,500 miles on the Bitter :banana:. Now off the road for winter.
Will be pulling dash apart to have speedo fixed, the stepper motor has issues w/ finding zero. Then I will be putting in a VDO tach that is the same as the speedo.
I also have to pull the steering column apart to fix/replace the ignition switch.
Always something to do. Very happy with the way it turned out.
This was the second harness that I have done, it can be a challenge, but just takes a little attention to detail.
Kevin
Administrator
Hey GS20,
Kevin
Let me know if you need a new switch Kevin.
I know you said you custom built the front suspension to fit the motor in..
Did you ever look at a GTO swap..? Just curious.. I can get a complete salvaged GTO (everything but motor and trans ) for less than $2000. Thinking Guages, BCM, ECM the whole shooting match.. maybe even the antilock brakes and traction control..
Hey GS20,
Will be pulling dash apart to have speedo fixed, the stepper motor has issues w/ finding zero....
Kevin
LOL
Just had a unit that couldn’t find "Home"...the speedo needle just went around the world.
Discussion Starter · #30 ·
If I were to do this again, I would use a newer V6 from a Camaro. Would probably be less of a problem w/ steering.
21 - 30 of 30 Posts
