Heya folks, have a question or two hopefully you can answer for me. I'm swapping motors from my parts car ('70 GT) into the driveable '69 GT. I plan on changing out just the block, head and header, everything else currently on the '69 is going to be used.
Aside from needing a valve cover gasket, header gasket, intake manifold gasket and the gasket for the piece that holds the thermostat, what other gaskets am I going to need to supply to the mechanic doing the swap? I plan on replacing the seals while i'm at it as well.
Not sure if it's of note but the parts car motor is hooked to a manual tranny (not going to be used) and is going into the '69 which has an automatic tranny in it.
Would appreciate anyone's time listing the gaskets i'm going to need for this project so I can get em ordered. Also, are the majority of these Opel specific gaskets that come only from a supplier such as OGTS, or can they be obtained from a local parts store?
Thanks folks,
Claud
(Doing the swap because the parts car motor has stalide valves and an autocross cam, etc, in it. I'm planning on rebuilding the motor currently in the '69 at a later date. It's original and not set up yet with hardened valve seats and such.)
Thanks folks,
Claud
