1 - 3 of 3 Posts
Pathologic Opeler
In JJ's _destec wiring diagram ..he mentions to cut the red wire to disable the european parking lights..which red wire is it?
(the european parking light function will drain your battery if the
directional signal lever is left r/or l with the engine off)
Pathologic Opeler
cut wire "F"
I scrapped off insulation at "f" and tested it with a volt meter.
It was hot when the euro light s were on and the key was out.
the Destec engineering said the euro lights were powered by a solid red wire..I cut it and insulated it...
Success! No more Euro lights to drain my battery.
PS:Truman..when you sat in my car on saturday...remeber how soft the detents were on my directional signal?I streteched out the spring to tighten the ball bearing detent...works solid now.
Call me on the cell if you need computer help..I will be watching the game...I don't think we can win this one.
1 - 3 of 3 Posts
