1 - 4 of 4 Posts
Graham,
OGTS sells them, and I happened to be "flush" one day and bought one. It was a bit expensive (at $33 USD!), considering it is just a foil-backed fiberglass sheet. You can buy the same stuff from your local home improvement centre (Rona or Home Depot; it's used as garage door insulation and such) and a version (albeit thicker) is widely used as wellhead and piping insulation in the oil patch. It also comes with a plastic "bubble" material inside, but it might not do as well in the heat of the engine compartment. It has been touted as a great low cost sound damper material. Go to "Beyond's" headliner posting at
http://www.opelgt.com/forums/showthread.php?s=&threadid=648
and his Nova site at
http://iola.com/71nova/nova-pics2002.html
where you can see it being used.
As for the dimensions, it is about 20 inches tall (in the picture; I can't recall what orientation it is installed in) and 17 inches wide. There is a slit near the top right hand vee that must be meant to wrap around something. I don't really have the technology to make a template, but it should be able to be cut to fit. Or maybe you could blow up this picture and use it as a template?
1 - 4 of 4 Posts
