Your memory is not foggy. But as you said that's with the larger 2.0 inlet valve. I stated to willis it's hard to break 100 cfm with stock valves....stock 1.9 valves. With a 2.0 valve it's not too hard at all. If you port the heck out of a 1.9 head with a 1.9 valve, you can break 100 cfm, but the port will be larger than the valve, which is a no-no. Throttle response will suck, and you may gain a few hp on the top end and give up a lot everywhere else. With a larger valve more proportionate to the port size, the low-lift airflow will improve, and you make gains everywhere in the powerband.Paul said:I vaguely remember you stating in a post on Classic Opels many months ago that the 42 mm 2.0 Intake valve bumped the flow up to 102 cfm @10". Foggy memory... If I remembered this correctly or didn't take it out of context, how much porting was required w/these valves to get this flow number? Meaning... was this an easy number to get, or did you have to work at it?
Thanks
Paul
OK this is way over my head ......but I just had a 1.9 head modified (1.72 intake/1.50 exhaust) in nearby Mexico at a respected porting shop and watched as he flow tested the finished head with 28" of water and 198CFM on the intake side...I do not recall the exahaust side. I am not certain this is good or not. He will test a stock head next time so I can see the percent of improvements....Any idea how this numbers would equate to one another???RallyBob said:The most I've ever gotten out of a 1.9 head was 137 cfm @ 10" of water (intake port). .
Because Rallybob has a limited budget! My flowbench will go up to 15" of water. Most heads are flowed at 10", or 25", or at 28". Generally the higher the number, the more accurate the flow can be measured, especially with minor changes such as valve seat angle, etc.asdasc said:That said, I have no understanding of why RallyBob does it one way or the other and it may be that 10" is a better test for an Opel head and 28" is best for a small block chevy.
Todd, a flowbench is basically a calibrated shop-vac. For a given line voltage, barometric pressure, humidity, altitude, and temperature, the electric motor will be able to pass a certain amount of air through an orifice (these factor into the calibration of the flowbench when it's set up). The flowbench simply lets you know what percentage of this amount of air the cylinder head ports are allowing to pass through.neuropel said:How do these things work?
I'm curious because I use similar equipment at work. Is it essentially just a matter of delivering a calibrated input and measuring flow out? I'm going to try a google search to see if I can find an explanation page. Again I'm clueless on how they work...is it a static measurement?
Believe it or not, some sleep apnea patients need up to 30cm (11.81") H2O pressure to splint their airway in order to keep breathing while asleep!![]()
Todd
Do you know at what valve lift these numbers were measured at?azopelnut said:he flow tested the finished head with 28" of water and 198CFM on the intake side.
It's only part of the recipe. If the airflow is great at .500" lift, but is crappy at .250" lift, and you have a .400" lift cam...you're in trouble! You will never reach that airflow numbers because of the lift of your cam, yet your valves are open at .250" at least twice for each cylinder's firing (as the valves open and as they close).asdasc said:One comment you made earlier in this thread is that the better flowing head didn't always perform better. I figured it automatically would. Can you elaborate a little?,
