I dont' know if I've asked before, but I couldnt find in with a search....
I saw somewhere that the flywheel bolts for a Pinto 2.0L will work with the Opel. Is this correct? ARP makes them in a hp set #151-2801. They are 10mm, not sure on length. Is this correct?
The other bolt question today is about pressure plate bolts. I have an S10 clutch and pressure plate. I've gotten the flywheel machined flat now it needs drilled and tapped, so I need to figure out what kind of bolts to use for this? Any suggestions on what 6 bolts to use to keep everything togeather?
Thanks
Dan
Thanks
Dan
